Silver
Reading the 12volt again check this out.
-Kickers voice coil is 2" while the 8500's is 3". 1" Increase.
Here are a couple Specs. (1st published), (2nd measured)
SD x Xmax = Vd
Kicker 100.0 in2 .51in 51.2in3
MTX 86.6 in2 .85in 73.6in3
Based on the public specs the MTX is 44% higher than the kickers. Which is 3.16db increase in output.
Kicker 100.0 in2 .4in 40.0in3
Based on the measured specs the MTX exceeds by 82%!
Danm...
Per Measured specs for THD+N @40hz, 500rms.
Kicker is 22.5%
MTX is 4.5%
Wow, 22.5% non-musical noise comin from those speakers. Fart away.
With the kicker, you do get 7% more cone area, BUT you give up 44% volume displacement and 3db of output.
These were in their reccomended boxed also. Owned.//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
SD x Xmax = Vd
Danm...
Kicker is 22.5%
MTX is 4.5%
