Mounting/Stacking Amps
all thread and some bolts
threaded rod with nuts on both sides of the amp to keep it suspended above the other amp. Might need an extra cooling fan or 2 to keep the air moving.
I thought about this but then how do I mount the 2 amps to the floor?
I don't not have access below.
I originally thought about some 4"-5" screws, but not sure how well that will work
I thought about this but then how do I mount the 2 amps to the floor?I don't not have access below.
make an amp rack from MDF for the bottom amp...Use a threaded rod through the amps as stated, drill holes in the amp rack, run the threaded rods through and put nuts/washers on the bottom to secure..
Secure the rack to the floor, AFTER carefully inspecting for obstructions/wiring/brake/fuel line/fuel tank etc...
mystang
"Cookie Monster"
mystang
SC
nuugen
Mike Mccabe
