Mounting Amp on Box?
uh oh! here we go again... this very same question started somewhat of a heated debate. alot of people mount their amps on the sub box (myself included) and i have even seen some high-end car audio salons (lol) do it. however, some say that the extra vibration caused by mounting directly to the box can shorten the life expectancy of the amp. by the way, if your box rattles too much you need a better box. search around the forum for a similar post and you will get more than an eye's full of (mis)information.
Don't know if I posted to that thread your talking about BUT boxes shouldn't vibrate. The AMP cann't esape vibrations if it's in the same car a the subs are in cause the subs vibrate everything in the car. Driving causes vibrations anyway. So don't worry about it.
I thought you had two amps?? What happened to the wood that you were going to have H.depot cut out?? Looks different to me for some reason. Do you...
9
Holefully he doesn’t hook batteries in series thinking it halves the voltage…..
29
It is a wives tale if the only evidence could be coincidental. I agree that vibration is bad for everything except women, but that doesn't mean...
32
5K
I would put two Eyelets on front and back close to the bottom of the enclosure with Toggles, rubber washers, and metal washer to seal the...
XplodX
XplodX
Mendocino,CA
Brutus2600
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
