Mounting a Sub on plexiglass....
Omarvelous
Queens, NY
Was wondering if there is anyone that would know much about mounting a sub on plexiglass?
The sub will either be a 12" XXX or 15" XXX.
Was wondering if
- 3/4" Plexiglass would be sufficient, and i could mount the sub on top OR
- Do a double baffle using 2 3/4" layer sheets of plexiglass, and mount on top OR
- Use 2 3/4" sheets, one for the mount hole (14 1/8" for the 15" for example) and the other to flush mount sub(the other at about 15 1/8" for the 15")?
The box i'm building will be a mix of fiberglass/mdf/plexiglass //content.invisioncic.com/y282845/emoticons/suave.gif.858fc102f7646e678ee8af7e1fbc41d1.gif
Just a possible thought for now.
Thank you! //content.invisioncic.com/y282845/emoticons/moon.gif.9d317aec3339ffe7fde0638df52c628a.gif
http://www.bcae1.com/plexi.htm
3/4" should be fine, because plexi is slightly stronger than MDF, but be very careful.
Also, remember plexi is very expensive. I just got a KILLER deal on 3/4" thick plexi, I got 1' x 2' for $20, only because it was leftovers and the company is moving facilites and needed to get rid of all their drop cuts... so it pays to call around I guess...
Good luck with the pelxi!
-----Nate
Yea all i really need is like not even 2' x 2'. Plus my boy that lives in chicago leave right next to one of the largest plexiglass producers, and can get it dirt cheap.
So you suggest my first suggestion
Yeah, I mean, a small 3/4" sheet is pretty **** strong, especially if the magnent is hanging down like that. If you were going to be facing it rearward or wanted to be more careful, 1" thick plexi should be plenty, but again, be REALLY careful mounting it and cutting the hole for the sub and everything... this is not something you want to do twice.
Holefully he doesn’t hook batteries in series thinking it halves the voltage…..
29
I would put two Eyelets on front and back close to the bottom of the enclosure with Toggles, rubber washers, and metal washer to seal the...
Actually the pods do not impact the sound of tweeters at all, it's all about location, reflections and pods while great in some locations, can be...
534
It is a wives tale if the only evidence could be coincidental. I agree that vibration is bad for everything except women, but that doesn't mean...
32
6K
Omarvelous
Omarvelous
Queens, NY
sound Q
    Jun 1, 2024
    May 31, 2024
