Most Efficient 2000w Amplifiers on the Market?
I looked into this one, and one thing i read is that the only Stetsom worth my time would be the 7k Vulcan, but also, the 2k isn't stable down to 1 ohm, only 2 ohms... Same problem with the Kicker 2500. Right now I'm trying to find out more information on pricing for the M2 and M3 from DD...
the good stetsom line is the digital/vulcan line.
the amps can do 1/2 ohm daily from what I have been hearing.
they just only listed rating to 2 ohms.
Where did you find these efficiency %'s? I have e-mailed them about the efficiency because their site only lists it as great than 70%. Did you measure it yourself?
Mmats have been known to have close to 90% efficiency for a while. Maybe its just on the birth sheets that says the actual number. They are also underrated.
its in the owners manuals, not on the site. MMats was originally a commercial laundry machine manufacturer who pretty much pioneered the Class D amps of today.
there is a formula you can use to figure it out IIRC...its something with the current draw, and voltage etc
Isn't that 90% at 4 ohms, though?
nope, because usually the efficiency is lower at higher ohm loads. the damping factor is higher at 4 ohms. NOT the efficiency. why doe you see specs that say efficiency at 1/3 power like 50% but at FULL POWER the efficiency gets considerably higher.
can't say that I have seen specs of amps that companies rated efficiency when only at 1/3 power.....
not sure i got what you are saying.
basically the efficiency of an amplifier decreases as you lower the ohm load/ resistance it sees
4 ohm nominal = 518 watts @ 88% efficiency (voltage fell from 14.3v, to 14.0v)2 ohm nominal = 948 watts @ 85% efficiency (voltage fell from 14.3v, to 13.6v)
1 ohm nominal = 1510 watts @ 78% efficiency (voltage fell from 14.3v, to 12.4 volts
.5 ohm nominal = 1615 watts @ 72% efficiency (voltage fell from 14.3v, to 11.8v)
.35 ohm nominal = 1748 watts @ 67% efficiency (voltage fell from 14.3v, to 11.4v)
http://www.soundsolutionsaudio.com/forum/index.php?showtopic=7116
lostdaytomorrow
lostdaytomorrow
Loc
lostdaytomorrow
