Mono vs. 2 channel amp
except dual 4 subs can only be wired to 1 ohm and 4 ohms, so unless the amp is 1 ohm stable or you get enough power at 4 ohms then no, you'll need a new amp.
No. A 2 channel amp that is stable at 2 ohms STEREO will work just fine. Hard to find one that isn't.
Eclipse 34230 isn't
//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif//content.invisioncic.com/y282845/emoticons/moon.gif.9d317aec3339ffe7fde0638df52c628a.gif
But as mentioned....don't bridge the 2-channel amplifier into a 1ohm load (unless specifically designed to do so). You could bridge the amplifier to both subs if you wired them together in series-parallel for a final 4ohm load.....more of a wiring headache, but IMO looks a little cleaner since there's less wires running to the amp. Or run one sub per channel at 2ohms.
Eclipse 34230 isn't
I was waiting for someone to post one that wasn't //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
mustangog2003
mustangog2003
Jemison,AL
ultimate157
