Mono or multi channel?
xFury
21
LV, NV
Hey everyone. I am having an issue with my current amp I got. It shuts down if I go pass 35% vol. so I am looking for a new amp to power my sub and maybe all the component speakers when I upgrade them in the future. I will be upgrading to a 12" sub in a few weeks, but I'm not sure if I want to go single or double.and will be upgrading to a decent componet set in the future.
Looking at the Dayton Ultimax 12 or Soundb or a Sundown. So what amp would be enough to power it? And should I just get a mono then get a lower power amp for the component? Going for a SQ setup.
Will be using factory radio also.
Budget: $200 +/-
Thanks
If you really want sound quality don't focus so much on power. Head room is great but not always affordable. Focus on a clean signal, and tuning capability. You want a way to put that sub bass right on the front dash
Sound good, so what would you recommned that is an upgrade from a 10" Kicker and a defective Eclipse? The budget is only for the Amp alone.
Thanks!
  • Locked
756
I get it. I'd never run a tone through at full tilt to test just how much they can take before it goes all willie nelson either 🤣
72
5K
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
Buy the 4 ch and keep the other. Usually on a 5 ch there isnt much of a substage, but there are a couple with a 1k @1ohm ch., but very few. A 5...
xFury
xFury
LV, NV
LosIsATool
