Mono OR 2-Channel
I would say it depends on the amount of power you want. You can use either style regardless, but the benefits of class D really don't start to take hold unless the power is high - at least several hundred watts.
If you only need - for example - 500 watts and you get a mono class D then it will always be a sub amp. If you get a 125x2 class a/b (500 bridged) and you eventually decide to upgrade it then you can move it to components or whatever.
Rob15Job47
Rob15Job47
CP
n2audio
michigan born
    May 14, 2026
michigan born
    May 14, 2026
