Mixing Batteries? bad? ok? no problem?
UNDERGROUND_BUM
I am just about to order my high output alt, and have a quik question is it ok to mix yellow tops with kinetik batts? the reason i ask is because i have Kinetik HC600 for my starter batt ( civic) and i have an extra yellow top (biggest one they make) that is about 5 months old and i am currently not using it. so i was thinking of putting the yellow top in the back and running the batts in parallel Good idea or bad?
I'm running a YT up front and a YT and Stinger PC2150 in the trunk with no problem. The only thing I wouldn't do is run a dry cell and a gel or wet battery together. Never done it, but I heard it can cause problems..
thanks alot......
cant wait to get no voltage drops with my new alt and batts //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
then i can upgrade all my shit.......civics alts ****
If you have a 1.5 motor prepare to lose all forward movment lmao //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
That motor is already low on power imagine it with 10 less or so //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If all the batteries aren't setting at the same voltage this will occur.But as long as the batteries are realitivly new and purchased around the same time you won't notice much effect.Especially if you put them on the charger every once and a while.But if you have one that is setting at say 12.1 and th rest are at 12.7.That one will pull current from the rest and this will go back and forth till there all dead.Just make sure to put a charger on them every once and a while and you should be fine.
UNDERGROUND_BUM
UNDERGROUND_BUM
HAWAII
audioarsonal
