Mitch86's S10 build
BTW, the deadening and weather stripping I've done on the doors has reduced rattles in my truck tremendously. Had a lot of rattles from under the door panel. Window regulator was loose on one side and had the rods in the door clanking together. Also the door panel itself had some clips broken off. I outlined the door with foam weatherstripping along with the deadening and replaced all the clips. I still have a lot of deadener left. Need to decide where it will help the most and finish off the roll I have. If I need more later I'll get some more.
Another very small update. But something is better than nothing,right? :D Got a little work done on my a-pillars. Had to unwrap and destroy the old pods off of them. Still gotta clean them up, but started on the new pods anyway.
Hot glued the hell out of it. Found out after I cut the hole out and everything that I should have gone a few inches higher with it.. but it will be ok for now.
Most of the shape came from hot glue.. a few thin layers of filler should make the shape I need. this is the first layer. may take forever to dry since it started raining and the only place i have to sit these are out on the porch. :crap:
Like I said, just a small update to keep the thread alive. @pro\-rabbit and I worked out a deal on a enclosure...so that should come soon. I dont get a lot of time to work on the truck, but once I get the box, Ill take a whole day and run wires, install batts,amp and enclosure and get this build all wrapped up hopefully!
Mitch86
Mitch86
Tennessee
Mitch86
