mini S harness
  • 3
jlm
ny,ny
anyone know of a source for the wiring harness for the head unit?
the antenna is a peculiar mini-coax and the harness connector has two groups of blade connectors (flanked by the blue areas) and two multi-pin connectors (at the bottom...one is grey, one is black )
photo attached of existing head unit, harness connector and antenna connector
thanks
john
i am replacing the head unit and need a plug/harness that will interface to the existing plug to which i can attach the leads from a new alpine 7897 HU.
the picture is so small because the server refused to accept a larger image! i reduced it three times before it would take...apparantly the max file size is 30k.
the mini is so new that no-one seems to lsit it. it may be that a new 5 series BMW harness will work, but so far i haven't seen one and can't be sure.
You found a BMW harnes???? cool.... the antenna looks like the same one as the new VW though. Good luck, this isn't a standard install.
Actually, just so you know..... In my VW I ended up leaving the stock HU and simply added a 4 channel amp to it using the high level input. Bridged two of the channels to a sub and paralleled the factory front & rears off of the other two channels......It's sounds fuc king great. You'd be suprised. You may want to re-evaluate why you're replacing the deck..................
mostly just my 2cents
I updated the original post to simplify it a bit and re-frame it with the new Scosche floating ground adapter. This adapter *is* different, as it...
4
  • Locked
I got a Gladen RC-90C2 thats pretty small 90x2 @ 4 ohms i'll be removing from my rig in a few days if interested.
So I am planning to build a system in my Ford Excursion and can’t decide on whether I want to use an iPad mini with a sound processor behind it or...
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
4
331
jlm
jlm
ny,ny
bean
winkychevelle
    May 24, 2024
