Mini Computer Speakers
I'm glad you like those speakers, as they're the only TB's I've ever thrown in the trash //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Close. They're buyout full range neo's from PE. They'll be going into a second set. Probably will wind up as a present for someone.
The terminals on the **** things are reeeally in the way of mounting... plus the flange has a gap, so mounting them on the front would probably result in ugly puckering in the metal around the screw. So I'm thinking about mounting these inside the enclosure from behind (maybe rabbeted 3/8") then wiring, run the wire through the back panel, line, stuff, and then attach the back. Then finish with the driver masked...hopefully avoiding damage.
WOOOOOOT!!!
Those little guys are the best I've bought. They don't cost much at all, plus they look ****ing amazing in my negro cabinets here. Dorm room audio has never been the same //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Yeah... not so much my idea.
What do you have as far as a crossover?
Cheap first order off PE (no time to build one) that I thre some NI resistors on to pad the tweeter. Brighter than ****in alpha centauri above 14khz, so it needed some help.
Nice build!...Inspired me!
Does anybody know where i could get that same style of amp but 30watts or so?
http://www.41hz.com/ has a kit that runs 25x2. The amp kit itself costs about 40 dollars, then you need the power supply kit which is like another 40 or you could use something like a laptop power brick.
Need bigger drivers and more power for a dorm. //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif:naughty:
Just be patient, o wise one. //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
Got a lot done with these today.
Wood:
Construction:
Baffle mockup (with masked drivers):
Mounted from rear:
After the backs were done I rounded over the back 4 sides, then lined the inside with dampnener, glued in felt, and glue in the power wires. I'll be ready to glue on the baffles and finish the roundovers tomorrow.
This set is going much faster than the first. Today I soldered in the wires, glued on the baffles, and did all of the roundovers and a good bit of the sanding.
Soldering earlier this morning:
And progress as of 10 mins ago:
hempy
bass wiener
hempy
nola
hempy
vegang
vegang
