Mid and tweeter set under $1000
hertz hsk 165xl... lol but im not nearly as well versed as a lot of people.
you probably know this, but wouldnt you be better off buying a 200$ comp set and spending the other 800$ on sealing your doors
$800 to seal doors?
This is for me to get ideas. If you already knew that check out my build log
I've had my XLs for a while and I still like them. Just time to change it up.
well, making it an airtight enclosure with all fiberglass and sound deadening inside like keep hope alive did to his car.
I did that with the last car. It had a true mid bass front stage. I didn't go as far with this one. Guess what? This one sounds just as good and it's only running a 2 way.
---------- Post added at 08:31 PM ---------- Previous post was at 08:31 PM ----------
As of now I'm down to Mille and K2Ps.
We sell Cerwin Vega and I have the ST65C Stroker components in my car. SPRO65C has an extremely loud tweeter which is probably the furthest thing from "SQ" that you can get in a small format. When I've talked about it with my sales rep he said one vehicle with the Stroker Pro components had the treble EQ bands dropped -12 dB to try to balance them with the woofers. For daily enjoyment SPRO65C is not going to do it for the OP, in my opinion.
Haha mine. 6.5" - beautiful midbass, 28mm silk dome. I read reviews somewhere that Ground Zero higher end comps were amazing. If you can find, rainbow platinums used (unlikely). Rainbow vanadium, but that's hard to find. New B2 ref comps under $400 are supposed to be a beauty. Lastly, I would also consider the Focal PS 165FX flax cone.
LosIsATool
LosIsATool
Pensacola, Florida
LosIsATool
