Watch your net volume... it's under 1.5ft3... and leave clearance with a side port to breathe.. 4" round=4" clearance... you can go less but its easy to adjust airspace to match your available spaceok...
Round is more efficient... idk why you are married to the idea of subs/port on the same face... you got plenty of space to play with... 1.6 tuned to 35-6hz... im out... too many cooks will burn the soup!having trouble getting a 4" port to fit. 14" high I can't change but the width and depth I can. The box width isn't long enough for the port tuning I want. I will keep trying. I would like a slot port though...
I'm not read the thread. I'm figuring out sub back, port out the side. 14" high is min and max can't change that dimension. The box needs to be deep enough for the sub, port and room to breathe like you said so thats about a 18" deep box or so. To get the airspace of 1.64 net with a torres tuning of 33.97 the width would need to be 17"". 4" port would need to be 15" long. The box would not be wide enough for that port length.Round is more efficient... idk why you are married to the idea of subs/port on the same face... you got plenty of space to play with... 1.6 tuned to 35-6hz... im out... too many cooks will burn the soup!
Cant do it now... id like to try to show ya... but Kush is correct try 2 ea 3" ports to make it work...I'm not read the thread. I'm figuring out sub back, port out the side. 14" high is min and max can't change that dimension. The box needs to be deep enough for the sub, port and room to breathe like you said so thats about a 18" deep box or so. To get the airspace of 1.64 net with a torres tuning of 33.97 the width would need to be 17"". 4" port would need to be 15" long. The box would not be wide enough for that port length.
4 x 13 port and 1.64 cf net would be 36.04 tuning. This box would be 14 x 19 x 16. Don't think its deep enough. A 14 x 17 x 18 is 1.65cf net with 35.94 tuning.Play with these volumes and port lengths and see if its close... Torres will have a lower tune probably. 1.65ft3 net 4"port 13"long
1.71cf w/ 4 x 13.5" is a 34.76 tuning. 14 x 17.5 x 18 dimensions. Not much port end to wall clearance only 3.25" or so. Need at least 4" clearance right with a 4" port?Bump up the volume to 1.7 and the length to 13.5"... what is it now?
Group delay and phase issues. I'd do 35. Bigger port on smallest recommended box.for metal i would not tune anywhere below 38hz. As a metal listener myself, there's barely anything below 40hz. So in the great words of kicker "anything under 40hz is a waste of information" lmfao.
