Mercedes E350 6th Order
iLL Ridge
NC
I've been planning on trying this for some time now.
My problem with a standard rear facing sub is cancellation and trunk rattles.
I always wanted to blow-thru the armrest hole/ ski-pass.
I went with two 10's in a .7 cu ft ported chamber for each.
Those are both ported to the middle chamber of around 2.5 cubes.
The removable final port plugs right through the ski-pass.
Only using 2- 4" ports for the exit. It somehow all works. And works well.
**** bangs!
Better than I expected. Clean. Clear. Solid. Flat.
Seems like it plays from 25-60 pretty **** flat.
Also----- VERY few rattles inside the vehicle from the rear deck/ trunk lid, etc.
I thought the box came out dope.First try.
No interest?
2 different subs? as far as the layout I like it. any reason you didn't use a slot port to better match the ski-pass?just wondering. I have also been pondering a similar setup using 3 10's
just testing. I want to trade my subs out.
They are some I had from previous projects.
Ports are cardboard. Thick walled 4 inch packing tubes.
I'll take pictures of everything sealed up and in the car.
Looks stealth with panels in place-- lol.
Bottom line---- best trunk bass I have ever had personally.
Sounds outstanding with all types of music.
Probably shouldn't work on paper---- but it does lol.
thinking about going with sealed 10's to make it a 4th order.
I got a dual 2 ohm xfl- wrong ohm load for running two subs--- and they take A LOT of power.
anywhooo......
Would you guys run a pair of alpine type s's in .7 cubes sealed each.. or
A pair of Rockville K6's ?
remember, this is for a 4th order box.
got rattle. And i've got mismatched subs. This was only temporary. I experiment.
yes i have had and heard many many subs in cars, trucks, minivans.... you get the point.
I'm not new.
got rattle. And i've got mismatched subs. This was only temporary. I experiment.yes i have had and heard many many subs in cars, trucks, minivans.... you get the point.
I'm not new.
I may try something similar in my CLK ..I can’t never seem to get the Bass right in it either ..I’ve tried multiple setups ..but have never tried firing into the cabin through the ski port
iLL Ridge
iLL Ridge
NC
iLL Ridge
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
