I guarantee you that the Hifonics Brutus in your signature WILL NOT deliver 1200 watts RMS unclipped at any frequencies you will be using it for!good hard bass and really clear and ive got 1200watts rms
how do you know?may be a buget amp but it puts out really good poweri think im gonna go with the mojo because of the cheaper price
my buddies got a 15" rockford t2 and has a hifonics amp hooked to it and has had no problems at all with the amp and it puts out the power that it says its supposed to.
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif I can make a Legacy or Pyramid amp put out its max power while hooked up to a volt meter and we all know they do rated power, rightvolt meter![]()
they will take 1500rms and up...I promisei had 2 mojo's it wont take more then 1500 true rms
but sounds **** good
u should be happy with either one
i had one of mine hooked up to a t15001bd(not sure if that is the exact name)they will take 1500rms and up...I promise
and MOJO's arent that great of a sounding sub IMO....others may disagree, but the ones I have heard havent and specs point that out as well
if u had to choose out of these 2 for SQ....the w7
I promise a MOJO can take 1500 watts like a champ.... they might have had it in the wrong box or didnt know what they were doingi had one of mine hooked up to a t15001bd(not sure if that is the exact name)the sub could not handle more then half way up on the gain
and all the settings were done at the local audio store with their volt meter or what ever they use to set amps with
Pretty odd because I had my mojo's on a MCD4kw and they took it just fine for about 6 month's until the car died. The right box and proper settings on the amp will make a world of a difference.i had one of mine hooked up to a t15001bd(not sure if that is the exact name)the sub could not handle more then half way up on the gain
Ive seen several setups with MOJOs taking anywhere from 4k-16k //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gifPretty odd because I had my mojo's on a MCD4kw and they took it just fine for about 6 month's until the car died. The right box and proper settings on the amp will make a world of a difference.
