memphis mojo 15d2 vs. jl3w7
i had 2 mojo's it wont take more then 1500 true rms
but sounds **** good
u should be happy with either one
they will take 1500rms and up...I promise
and MOJO's arent that great of a sounding sub IMO....others may disagree, but the ones I have heard havent and specs point that out as well
if u had to choose out of these 2 for SQ....the w7
i had one of mine hooked up to a t15001bd(not sure if that is the exact name)
the sub could not handle more then half way up on the gain
and all the settings were done at the local audio store with their volt meter or what ever they use to set amps with
i had one of mine hooked up to a t15001bd(not sure if that is the exact name)the sub could not handle more then half way up on the gain
I promise a MOJO can take 1500 watts like a champ.... they might have had it in the wrong box or didnt know what they were doing
Pretty odd because I had my mojo's on a MCD4kw and they took it just fine for about 6 month's until the car died. The right box and proper settings on the amp will make a world of a difference.
Ive seen several setups with MOJOs taking anywhere from 4k-16k //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
pretty sure it does i talked to the jl dealer and he said that the amp will be good for the sub..and if it blows...then i take it back and get a new one..thats what warranty is for:)
i work retail and i hate people like you, thats not what a warranty is for //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
so company A has to charge more for stuff because idiots dont know how to set amps and end up blowing stuff up and want new subs/amps cause they dont know WTF they are doing and its got a "warranty" so they want new ones NOW!!!
AHHHH!!! DRIVES ME CRAZY
if you get a JL i hope they laugh at you in your face when you bring black a smoked W7
...end of rant
on a side note,i say mojo, but i like old ones better than new ones so ehh
It is running your amp at .75 ohms that is up for debate. I don't think your sub will get enough power from that BXi 1208d @ 3 ohms with the coils wired in series and I don't know if your amp will like a .75 ohm load with your coils in parallel.
I am going to go against the grain and say to only go with the MOJO if you want SPL. I have yet to be impressed by the Memphis MOJO series of subs because they just sound weird to me.
You're not suppose to turn the gains halfway and 3/4s and such. If you set the gains to match your radio voltage, that Mojo would swallow 1500 watts. I believe two Mojo 15"s would run nicely on a 4kw.
if the amp doesnt bump the 13w7 good enough then ill sell that one and get a bigger amp
at least the amp wasnt alot of $
..but im not looking for competition loudness...not trying to run it at its maxx/peak performance..
so ill see how it goes i guess
mojos prob. sound wierd to you because they dont give you very clean bass, they are made for comps. to be loud as helll, 13w7 is for loudness and clearness...im looking for the clear bass
jeepdriver001
jeepdriver001
Crystal lake, Il
jeepdriver001
michigan born
    May 14, 2026
michigan born
    May 14, 2026
