memphis mojo 15d2 vs. jl3w7
good hard bass and really clear and ive got 1200watts rms
I guarantee you that the Hifonics Brutus in your signature WILL NOT deliver 1200 watts RMS unclipped at any frequencies you will be using it for!
So aside from being lucky to get 1,000 watts RMS @ 1 ohm, you have a slight problem with the way a 13w7 rates with its dual 1.5 ohm coils. Will your Brutus survive daily @ .75 ohms? Some run fine @ .5 ohms whereas others pop @ 1 ohm. I guess the subwoofer you choose depends on how lucky you feel:laugh:
Notice I said "unclipped". I watched a BXi 1608d start to clip @ 40 volts of output, or 800 watts RMS, on a 2 ohm load hooked directly to the subs! That is a tad bit less than the 1,100 watts RMS that amp is supposed to deliver at 2 ohms, but what more should one expect from a budget amp?
may be a buget amp but it puts out really good power
i think im gonna go with the mojo because of the cheaper price
my buddies got a 15" rockford t2 and has a hifonics amp hooked to it and has had no problems at all with the amp and it puts out the power that it says its supposed to.
may be a buget amp but it puts out really good poweri think im gonna go with the mojo because of the cheaper price
how do you know?
jeepdriver001
jeepdriver001
Crystal lake, Il
jeepdriver001
