hey guys , ive got a mc1.100 class d amp(550x1@2ohm ,1100x1@1 ohm), im going to be running 2 - 12" dvc 4 ohm(500w rms) flat subs (memphis) , im confused the smaller amps ( the 1.250 and 1.500) only have the mono or 1 set of + and - terminals , on my amp or the bigger amps there are 2 sets of + and - terminals mono amp ? Its like having 2 channels? ,If i run my subs down to 2 ohms i will have 2 sets of wires to install into each of the 2 terminals/channels , i understand that but if i run the 2 subs togther into 1 ohm i will only have 1 set of wires to hook up to amp the + and - , how would i hook end of sub wire to the amp ? would i connect like im bridging a 2 channel amp? or just install into 1 set of the terminals and the amp will know? Also amp is about 50 w more rms then called for on subs would i be better off running them at 1 or 2 ohms? thanks for any advice
