Melted Fuse?!?!
notoriousroc1
MD
Problem is I noticed that the fuse on my 1/0 gauge going towards my battery has half of the plastic melted (but only on the side of the fuse facing the battery). My setup is as follows:
Stockish battery
200A EA Alt
Rockford T20001bd on Kicker 1/0 gauge (100A fuse on wire)
Rockford P400.4 on Rockford 8 gauge (60A fuse on wire)
T20001bd running to Audioque HDC312 at 1ohm
BIG2 done (need to do Alt + to Batt +)
I know my fuse on 1/0 gauge is way too small (the T20001bd has an internal fuse of 250A), but why would one half of my 100A fuse be melted? Doesn't make any sense. Again, its specifically the side of the fuse facing the battery, the other leg of the fuse (facing the amp) is just fine.
Stockish battery
200A EA Alt
Rockford T20001bd on Kicker 1/0 gauge (100A fuse on wire)Rockford P400.4 on Rockford 8 gauge (60A fuse on wire)
how does it not make sense? you are trying to draw 250 amps thru a 100 amp device.....
Stockish battery
200A EA Alt
Makes perfect sense.
In otherwords your amp is pulling to much power from your alt and due to the heat from the electircity traveling thru your 0g to your fuse it melted
not quite...
the alt is irrelevant here... it is the fuse and only the fuse that is the issue here...
250A of current trying to pass thru a 100a fuse...do the math //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif...
Understood. I don't have the amp turned up all the way, and I didn't have this problem running it at 3ohms on my W7...thats the reason why I asked.
possibly because the the higher ohm load meant less power produced by the amp, therefore less amp draw. If you actually ran the same amount of power then as you are now, I'm sure that w7 would've melted along with the fuse.
Melted due to.....clipping??? Would an amp clip early due to low voltage?
I am truly surprised the fuse has not blown. i would suggest buying better fuses. if your pulling that kind of amperage through that fuse it should have blown before the plastic melted. the fuse is designed to handle up too 100amps not until the plastic melts off either side. The fuses job is too protect your wire from point a to point b. it doesn't sound like its doing its job.
ok now this has been bugging me lol. sicaudio is probably correct in the cheap holder. the only other thing i could think of was a loose fitting fuse on the battery side arcing in the fuse holder creating a crap load of heat. This could explain why the fuse never blew. You might not be pulling your 100 amps. a loose connection could easily do this. check the fuse holder
I made a lot of money repairing fuse boxes that were destroyed from people taping into them. Pay once by doing it right. Do it wrong, the second...
14
410
It would be cheaper, it might be easier to find a place to mount it, and you would have a ton of options if you just do two, 3 slot fuse holders...
638
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
I plan on getting the fuse to run as a front sub/midbass in my kick panels...I've heard they sound good but you definitely wont get mirror shaking...
notoriousroc1
notoriousroc1
MD
Bob Saget
    May 24, 2024
    May 23, 2024
