measuring watts??
No. bigger the impedance load, bigger the resistance of flow of power to the subs = less power.
no resistance means the most power.
8 ohms of resistance restricts the amp more than 4 ohms does and thus you double the power by cutting the resistance in half
ok I see what you were talking about now, make complete sense. The amp will run just above the short protect with no impedance load.
Best thread Ive read in a while
Anyone care to explain imp rise in english? Like I wired my (4) DVC 4ohm subs to a 2ohm load on my amp. What actual load would my amp be seeing? Not likes theres any way I can wire all 4 of them to a lower load if the imp rise is to much. But Id like to know
No impedance load implies infinite resistance, not zero resistance. Zero resistance is a short.
Checking the AC voltage of an amp with no load USUALLY works, but not always depending on the topology of the amp. To find the actual power out, as said before you need a clamp ammeter, a voltmeter, and a test tone. That gives you the true power by multiplying amps x voltage.
Impeadnce rise only matters when burping.Music is transient so the actual impeadnce is constantly changing.
You could wire down to .5 ohm if your amp is stable at that.
yes i know this, I stated his before that If he wants to calculate the power going to his speakers he needs to leave them hooked up so he gets a reading with the impedance load from the speakers. If he unhooked the speakers he would get the maximum rms the amp will produce if it has a non regulated output, he has a impedance load that he should take into effect. He is not trying to measure the full potential of the amp, he is trying to figure out the power going to his speakers when they are hooked up.
Fair enough.
On another point on the OP's question: When playing regular music any number you got would be swinging wildly. Only a test tone would give you a consistent number.
In all of this ohms law BS, EVERY SINGLE ONE of you missed another vital piece of the puzzle. One better have an oscilloscope to watch the waveform (eta on a constant test tone) otherwise there is no way to determine clipped power from clean power.
Otherwise one will be saying "ZOMG, muh 1,000 watt amp produces 1,700 watts RMS. Look at muh proofz!":rolleyes:
Clipped or clean its still power.If you know what your doing you will get fairly accurate results without an Oscope.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
What exactly is that distortion percentage where most humans start to determine signs of clipping on subwoofers again?
Oh that is right, you know what you are doing and can obtain precise mesurements with only part of the puzzle.//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
x2... I always use my oscilloscope when testing the output power of a amplifier that I have just repaired or bought. I also use it when setting the gain. As long as you know your divisions and your equations when using the graph on a oscilloscope you should get a very accurate reading.
The human ear can only pick up about 10% t.h.d and above.
now when you say " i always use my O'scope when testing the output..." are you just talking about the setting the gain part...as in checking for clipping...or actually finding the constant output of amp by only using scope?
cause i want to do the same thing, measure the RMS output of my amp, but i only have a o'scope, im gonna get the clamp and DMM soon though, whats crazy is i got a EZdigital 5060a 60MHz 2channel scope in perfect working order for 10bucks from my school, and i know it works cause i tested it myself. im in my 7th quarter at ITT tech for electronics...love it
so im pretty sure im not going to be able to do this since im going to need a clamp meter for current, and a DMM for impedance,
cause P=IV, but what about the equation P=(V^2) / ®.... which is the same thing, could i square my voltage and divide by my sub load...anyone ever found it that way?
or am i SOL and theres no possible way to measure RMS wattage with only an O'scope...
thanks in advance for any advice.
It sounds like you want to measure actual power to the speakers with music. Put your meters on average responding and play your music. This will give you apparent power, finding actual power would be quite difficult without a powermeter. You can use a program like speakerworkshop to measure % THD if you are so inclined.
mat3833
mat3833
florida
SlowLoudNBangin
