Measuring Voltage
I know you can but do you just put the leads on your battery terminals?
That depends on what voltage you are looking for. You will see small differences in voltage throughout your vehicle depending on the setup. If you are looking for the voltage of your battery, check at the battery terminals. If you are looking to see what voltage your amps are seeing, check at the amps power inputs.
^^^this
I was going to type it all, but loop beat me too it:D
I hazent much.....I are teh poorz ATM
Tax refund FTW:woot:
You and me both!
I was actually referring to this (see red circle):
yes I know.....but for the .5 second it took me to type that, I made nothing:crap:
I was hoping that my post might serve as credit towards your saved time, hence more paper? //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Tested the power terminals on my amp and it was between 14-14.4 cranked up with a bass test. I'm assuming that's good?
That should be very good. Most people would expect to see more than a 0.4v drop under heavy bass notes. You can try a test tone for 30 seconds or so to see if that number drops. But if it stays above 14.0v with your usage, that is gravy. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
adio25
adio25
Wausau, WI
loopkiller
