MB Quart Amps
sullirock
I might have missed this answer somewhere in the forum (I did look, however). But I'm looking into getting a 4 channel amp to power some MB Quart speakers. I thought it would be logical to pick a MB Quart amp. I really don't know which brands are considered top quality as far as for amps go. Please direct me to the best quality amp I can buy if MB Quart is a crappy amp manufacturer. Gracias!
The MB Quart Discus line of amplifiers is good, a lot of people here run them and recommend them all the time, especially the DSC4125 (4 channel amp) and DSC2000.1D (mono); MBQ is hard to beat for the price.
There are many other brands that very good, however - Audioque and Sundown are two more brands that are at the top of the list.
And just to get this out of the way, Matching speaker brands and amplifier brands is purely aesthetic - it won't give your setup some magical boost in quality, no matter what any one tells you.
I'm interested in getting the 4 channel as I've seen the positive reviews on this site. Just wondering if the MB Quart DSC4125 will sound just as good as the Esoteric Audio E7152 I have. Basically want good sound quality with more power
Thanks for the replies everyone. I'm glad to hear that MBQ amps are high quality. I want good quality and dependability but I also want a good price. I thought about JL but they were quite up there in price! I don't need more than 500W RMS@4ohms. The JL's pricing made that difficult for me as opposed to MBQ. I appreciate all the help, y'all I'm gonna check out those Audioques and Sundowns!
I was looking at the MB Quart DSC450 for myself, but I noticed the HP filters only go down to 10kHz. If you need a HP for mid-range, you'd have to use an additional x-over.
I just bought my MB Quart DCS4125 so I havent really been able to say how good it is, but I know it was a great buy! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I'm rather new at this. What is the purpose of a High Pass filter? I guess that is what HP filter means.
I looked at the specs on that MB Quart DSC450 again and it looks like I misread the HP filter range. The HP filter goes down to 10Hz not 10kHz. Most people can’t hear much below 20Hz, so 10Hz is a really good range. This amp is really cheap at $100 too.
A high pass filter removes lower frequencies from the signal entering a speaker. Typically, the larger the speaker the lower frequency the speaker can reproduce without distortion.
MB Quart are better than Boss, Power Acoustik and whatever other flea market brands there are but they won't be near the quality of Arc Audio, Helix, McIntosh, older Soundstream, older PPI Art Series, older Orion, Zapco.
You get what you pay for in the end.
You get what you pay for in the end.[/QUO
That is so not true i used to own a old school orion amp and i replace it with a mb quart raa2400 and the mb quart was way better than the orion in sound quality
Yeah, I'm seriously considering the MB Quart DSC 480. For a 4-speaker MB Quart setup consisting of MB Quart DSH 216 components and MB Quart DKG 116 rear speakers. As well as putting in two Rockford Fosgate P3D212 subs. And, of course, a second and third amp to power them independently. But here is the issue: the power coming from all of this is well over 1000W RMS. The MB Quart DSC 480 only allows a 4-gauge power wire. Reading up, I found that if I have a system with more than 1000W (don't know if they meant RMS or Peak), I need a 0/1 gauge amplifier power wire. I like the MBQDSC480. Will I have to change my choice of amp?? Not to mention, I don't even know what amps to buy for the subs?! Tough decisions.....
MB Quart DSC 480:
Amplifier Class AB
Number of Channels 4
RMS Power (4 ohms) 80 watts x 4 channels
RMS Power (2 ohms) 160 watts x 4 channels
RMS Power (1 ohm) N/A
Bridged RMS Power 320 watts x 2 channels
Total RMS Power Output 640 watts
Peak Power Output Not Specified
Total Peak Power Output N/A
Maximum Input Gauge Size 4
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 Ohms
THD at Rated RMS Power 0.05%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover Low-pass (LP)
High-pass (HP)
Full (AP)
High-Pass Crossover Frequency 10 - 1200 Hz
Low-Pass Crossover Frequency 30 - 150 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio 92 dB
Channel Separation 80 dB
Bass Boost 0 - 9 dB
Bass/Gain Remote Optional (Accessory required and sold separately)
Fan Cooled No
Fuse Rating 30A x 2
CEA-2006 Compliant No
MB Quart DSH 216:
Speaker Size 6-1/2"
Design 2-way Component System
Tweeter Design Cone
Tweeter Composition N/A
Woofer Composition Polypropylene
Woofer Surround Rubber
Peak Power Handling 120 watts
RMS Power Handling 50 watts
Sensitivity 87 dB
Frequency Response 40 - 32000 Hz
Impedance (per voice coil) 4 ohms
Top Mount Depth 2-3/8"
Bottom-mount depth N/A
Cutout Dimensions 5-7/8"
MB Quart DKG 116
Speaker Size 6-1/2"
Design 2-way
Tweeter Design Dome
Tweeter Composition Titanium
Sensitivity N/A
Top Mount Depth 2-2/5"
Cutout Dimensions 5-3/5
Speaker Grilles N/A
Rockford Fosgate P3D212:
Subwoofer Size 12"
Subwoofer Design Round / Circle
Main Cone Color Black
Voice Coil(s) Dual (2 voice coils)
Impedance (per voice coil) 2 ohms
Peak Power Handling 1000 watts
RMS Power Handling 500 watts
Woofer Composition Kevlar Fiber
Woofer Surround Poly-Ether-Ester
Minimum Sealed Box Volume .75 cubic feet
Maximum Sealed Box Volume 1.25 cubic feet
Minimum Ported Box Volume 1.79 cubic feet
Maximum Ported Box Volume 1.79 cubic feet
Sensitivity 84 dB
Frequency Response 27 - 250 Hz
Xmax (millimeters) 16.4 mm
Top Mount Depth 6-3/4"
Shallow Mount Installation No
Cutout Diameter 11-1/4"
Recommended Enclosure Type Ported / Vented
Sealed
Subwoofer Grille Optional (Accessory required and sold separately)
* Rockford Fosgate P312G
Re-Cone Kit Available No
sullirock
sullirock
Virginia Beach, VA
Sir-Lancelot
Doxquzme
    Jun 18, 2026
Doxquzme
    Jun 18, 2026
