netherland24
camry
well i was trying to get some info on the QAA amps.. but nottin yet.. was wondering what power it does at 1ohm?... also is it 1ohm stable or 2ohm stable?
Hey Nether. I notice you are running a raa-4200.What are the differences between the RAA & QAA? I'm currently looking at puting an active system in my F150 and am trying to sort through 4 channel amp decision HELL myself.Also, any other amps you could suggest I should check out?Thanx lots
At one point I was looking at the QAA lineup, so I went to the Rockford forum and asked questions and what I found was that the RAA line is roughly on par or maybe a notch above the Rockford Punch line and that the QAA was on par with the Rockford Power/RF line.....All the Quart amps were built by Rockford when Quart was owned by Rockford......hope this helps some...//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifWhat are the differences between the RAA & QAA?
Go over to Rockfords website and long onto the forum, there is lots of info on those amps over there and there is always someone willing to answer all your questions about them......//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifreally.. power series hmm... still wish i could get some spec's on them.
thanks forgot to check those Y connectors. thanks hahahwhat do you mean link two of them together?
one IDMAX off of each RAA1000? Ifs so, why woudl you need to "link" them together? Just get an RCA splitter so each amp can get the sam signal.
not sure if this helps but...(I didn't read the thread, just the title //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif )thanks forgot to check those Y connectors. thanks hahah
any info in QAA AMPS? worth it? i have a RAA1000 and RAA4200 worth getting the QAA version?
