Central Region May 2nd Alsip IL
IA,IL,IN,KS,MI,MO,MN,NE,OH,OK,TX,WI
What are the classes?You should just hold a db drag you will get a better turn out..........
3 classes: 0-1000 101-3000 3001-unlimited on there website
I have lots of family in Worth & Chicago. I may check out the show in August...
Worth is right down the block. come and check it out
trying to get the day off for this one. Always a good time at these shows, nice people running it and good food. They use an AC190 that is around .1dB off the TL...
Hmmm so the class's are put together by wattage?
So my Tib has 7k+ & would be in 3001-unlimited
The Highlander has 1500 & would be in 1001-3000
I am just seeing & if that is the case I probably wont compete........
Nice, well I will be there....its about 2 miles from my house....
I am in the 3000 watt club but maybe not!! is it RMS or PEAK?
My amp is 3000 RMS who knows what it peaks at, it doesnt say.
Plus Its kinda weird to have it that way because who can tell if someone has their amp at 1.5 Ohm or 1 ohm or what...
Well i will ad another battery for this show.....
Oh well its for fun anyway....It will be a good time!!!!
Nice, well I will be there....its about 2 miles from my house....I am in the 3000 watt club but maybe not!! is it RMS or PEAK?
they do it like USACI. your 4ohm rating.
x2 4ohm rating
Pretty laid back, not some super serious comp, so just come out and have fun and throw it on the meter. They also do a 3 run average and last run you can meter in the kick, in the port, or whatever....
Sleepy killed me with his port score...
Had a set of Ecplise 6x9's back in the day in my '99 Grand Cherokee. The SE8495s iirc those were so sweet sounding. Wish I hadn't sold the GC with...
Yes Frame is best if second battery is in the rear.There are plenty of bolts and even unused holes in the Frame that can be used for an excellent...
Just want a give an update. I ended up trying a capacitor to see if it would work before spending on a battery. The capacitor does work, the...
mdbgshft
mdbgshft
Chi Town
BigJoker
    May 20, 2024
    May 20, 2024
