Massive Audio RK6 Series Comps & Co-ax
davidtemple
Caraudio Guru
I have 2 sets of each BNIB...
RK6 Comp set- $225
RX6 Coax - $175
Brand New in Boxes
RK6 Comp set- $225
RX6 Coax - $175
RX6 2 way coax 400w/200wRMS 92DB Sensitivity
Weight 23.00 Pounds
Speaker Size 6.5
Tweeter 25mm Silk Dome
Cone Glass Fiber
Sensitivity 90 dB
Frequency 65-20KHz
RMS Power 50-200w
Peak Power 400w
Impedance 4 Ohm
Crossover 6 dB Internal
Basket Cast
Depth 2.75"
RK6 2-way component 500w/250wRMS 92 db Sensitivity
Weight 25.00 Pounds
Speaker Size 6.5
Tweeter 28mm Silk Dome
Cone Glass Fiber
Sensitivity 90 dB
Frequency 65-20KHz
RMS Power 50-250w
Peak Power 500w
Impedance 4 Ohm
Crossover 12db External
Basket Cast
Depth 2.75"
I have a few references / feedback on here over 130 on Diyma - LINK
I wish I could just get the woofers on these....nice comps and killleerrrr price...pm me if u could possibly sell the woofers alone
i do the same mids with tweeters the RX6's you could disable the wire on the tweeter and use as the mid same woofer as the RK6 for $115 shipped just the 2 6.5" speakers.
got 2 sets of the rk6 comps left? i am looking for some serious midrange to cover from 200 hz to 2.5k, running a dd 1508 in each front door from 50-200hz and a selenium horn from 2.5k up. if you think 2 pair could keep up and cover the needed range pm me.
yes they could do that easily.
pm sent
davidtemple
Caraudio Guru
davidtemple
Louisville, KY
Bassin Brandon
