massive audio
  1. A
    Completed Massive audio 15" dmx stage 2
    My first sub was a 15 in massive audio dmx stage 2. I am unsure what happened to it. I am wanting another 1 for my new car and cannot find 1 for sale anywhere. So if anyone knows of 1 I would love to buy it.
  2. A
    Massive Audio Torox 104 versus Power Acoustik GW3-10?
    Greetings folks, I am just interested in getting some opinions, experience, thoughts on whether I should choose the Massive Audio Torox 104 or the Power Acoustik GW3-10 for my truck. I will be installing one of these subs in an under-seat coated 1 cu. ft. enclosure (sealed). The sub will be...
  3. Louisiana_CRX
    Massive Audio NX4 Brand New
    Item(s) for Sale: Massive audio NX4 Item(s) Description/Condition: Brand new ..4ch amplifier 4x100 ....never used or abused Price: $130 shipped CONUS Shipping and Miscellaneous Item Information: FREE FREE FREE !!!! Item Pictures:
  4. J
    new here!!
    Hey whats up , my names jason i drive a mercedes benz 300sd turbo diesel. I trade vehicles a lot but might stick with this one for awhile. I have a alpine head unit , two massive sumo tens in a vent port custom built box running at 1 ohm off a memphis 1000.1 mono block amp . sounds good as hell...
  5. C
    Sundown SA-12 questions
    Im debating on buying either an SA-12 D2 or a Massive Audio Hippo 122 for a single vented box (1.75/3.28gross; cubic feet) port tuned @ 35hz. Im powering them with a RF t1000 which puts out 1500 watts @ 1 ohm. Would an SA-12 be able to handle 1500 watts being its RMS is 600? Im sure an MA Hippo...
  6. trumpet
    Massive Audio NX2 120W x 2
    Item(s) for Sale: Massive Audio NX2 Nano Block 2 Channel Amplifier Item(s) Description/Condition: New Everything you would expect in a state of the art power amplifier is here in "Nano Block". Adjustable Hi/Lo 24dB X-Overs, 12dB bass boost control, 24dB sub harmonic filter, Dual sided mil...
  7. trumpet
    Item(s) for Sale: Massive Audio NX2 1 in stock Item(s) Description/Condition: New Massive Audio Nano Block amplifiers are small Class A/B amps. Measuring roughly 7″ long x 5.5″ wide x 2″ tall the NX2 can fit almost anywhere. Not much trunk space? Stash it behind a panel, under your...
  8. Massive Subs
    Massive Subs
    dc12's a way underated sub at 600watts rms
  9. trumpet
    Massive Audio Nano BiT BX2 2-Channel TINY amp
    Item(s) for Sale: Massive Audio BX2 Item(s) Description/Condition: NIB If you need an extremely small amplifier which doesn't lack in features you need to consider the new Nano BiT amplifiers. Technological advances have allowed Massive Audio to one-up the Nano series by shrinking the...
  10. trumpet
    Used Massive Audio N2 800W x 1 at 1 Ohm
    Item(s) for Sale: Massive Audio N2 Item(s) Description/Condition: Used I ran this amp for nearly 2 years with no issues. Most of this time I ran it at 1 Ohm under my driver's seat. With a DMM I measured enough voltage to equal 600W with the engine off while my sub was wired for a 1 Ohm load...
  11. Kanjay West
    Should I do it?
    A guy is trying to sell me a 10" Massive Audio (Massive Audio TW 10, I believe, from the pic he sent me). He wants to sell it to me in a custom ported box and an amp (1000w) for $150. Should I take him up on the offer? Or should I go lower? Are Massive Audios good subs? Thanks for your...
  12. D
    Box for Massive Toro 122
    I am trying to help out a friend and have turned up with absolutely nothing. He has come to me for box plans for his new sub, Massive audio Toro 12 2 ohm dvc. I built a box for my kicker l5 15" that turns head and would make you think twice about buying kicker, so he wants that same kinda wow...
  13. R34P3R
    Massive Audio N4
    Item(s) for Sale: Massive Audio N4 2K RMS Monoblock Item(s) Description/Condition: Minty Fresh. Bought from GBob2003. No scratches, scuffs, or marks of any kind. Will ship with original box with foam inserts and UNWRAPPED manual. Does have 4 Gauge inputs. Really frickin tiny. Price: $300...
  14. massiveaudio
    Massive Audio’s NEW “Volt” Amplifiers Now Shipping
    “Massive Audio’s NEW “Volt” Amplifiers Now Shipping!” Jump In, Buckle Up and remember to “Keep Your Ears Inside Your Ride at All Times.” Everyone knows that California is going to fall into the Pacific Ocean sooner or later, so before it goes you better power up one of the three NEW “V”...
  15. O
    Massive Audio NX4 - protect mode when ran pretty hard.
    I just bought and installed a NX4 (100w RMS x 4 @ 4 ohm)amplifier in my car to replace a Kenwood KAC-8452 (70A RMS x 4 @ 4ohm) I was running. When run relatively hard/loud, it seems to heat up and the protect light comes on. I tried to match my speakers with an amp that was at least as high...
  16. G
    Low End Theory #2: Help me pick a DIFFERENT sub :(
    I was dead set on using Shiva X-2s in my setup. However the June ETA date came and went, and now Kevin tells me that his manufacturer is basically non-functional and no eta on when/if new Shivas will be made. So I need to pick between my alternatives (unless you are lookin to sell a 12" Shiva in...
  17. davidtemple
    Massive Audio RK6 Series Comps & Co-ax
    Item(s) for Sale: I have 2 sets of each BNIB... RK6 Comp set- $225 RX6 Coax - $175 Item(s) Description/Condition: Brand New in Boxes Price: RK6 Comp set- $225 RX6 Coax - $175 Shipping and Miscellaneous Item Information: RX6 2 way coax 400w/200wRMS 92DB Sensitivity Weight 23.00 Pounds...
  18. M
    Any one had experience w/ massive audio PA100 or any other of the precision line amps
    I just picked up a massive audio PA100 amp. Im having trouble finding any info or specs online but it appears to be a pretty solid built amp. It came with 3 x 30A fuses and the amp its self is pretty large/heavy. If anyone could give me any info or opinions about this amp please help me out! thanks
