Massive amps anyone?
I'd stay away from the nano's. I had the NX5 and it overheated and went into protect without an external fan on it. I believe they do rated though if you have the proper electrical and air flow.
I Actually Have A Massive Audio CA 200 Amp That I May Be Willing To Part With
Power @ 12.6 volts
75 WATTS X 2 @ 4 Ohms
250 WATTS X 2 @ 2 Ohms
1000 WATTS X 2 @ 1 Ohm
250 WATTS X 1 @ 4 Ohms
2000 WATTS X 1 @ 2 Ohms
Offer?
The NX4 and NX5 appear to be overrated on the full range channels. They also tend to run hot (the full range channels are class A/B). Nothing special IMO. If you want a compact amplifier, get a Class D amplifier. If you want Class A/B, then having small heat-sink doesn't help with cooling.
bowhunter
bowhunter
Raleigh
Falcons
