Proof? Ummm how bout the fact that electronic stability control "ESP" as Audi calls it (Electronic stability program,) DID NOT exist in a production model of ANYTHING until 1995. And if i'm not mistaken not in audi until a few years later.
Bosch - ESP ? driving safety into the future
Electronic Stability Control - Wikicars
You are either lying, Or too stupid to realize your car isn't a 1994. Either wouldn't surprise me.
Are you sure? No turbo's don't use engine power exactly, they use exhaust pressure. Exhaust is essentially engine waste, the only thing a turbo does is slightly increase exhaust back pressure which accounts for at most (if you didn't do something stupid) a 2-3 hp loss. and besides that your valves need a specific amount of back pressure meaning you would have to re-tune and likely could account for the gain of back pressure with exhaust systems.
All of this is forgetting the fact that this is the case when installing after-market turbos. Obviously the stock exhaust system in a non-turbo engine wasn't designed to accommodate a turbo.
Yours however, IS a factory turbo, meaning that the exhaust system was pre-paired with the turbo to supply the optimal amount of exhaust back pressure to the engine.
In a nutshell, this means you are wrong. You would see dramatic losses at EVERY RPM level where your measly 2.2 i5 naturally aspirated. You truly are an idiot if you can't see that.
Read above, low end torque would be the same or worse, just because you don't get the full effects of boosting until the turbo spins up for a split second doesn't mean it doesn't give better low-end performance.
Paint is a higher grade? now your just pulling stuff out your az. There was a recall on a specific lot of black eclipses due to an error in the mixing process, mine wasn't included and as you can see from photos, my car shines more than most brand new cars. I don't think any manufacturer has ever painted a car 5000 coats, in fact id wager the highest number to be about 5 or 6.
All that is pure opinion, not an ounce of fact to it, thus I won't address it. There are alot of people who have said my car it one of the prettiest they've ever seen. and nothing else looks like it, i think your car looks just like every other early 90's car. Your comparing your '94 $4000 audio to a lambo miura for a timeless body style? BAHAHAHAHAHAHA this is a car that goes for around $600,000 - $700,000. A little delusional are we? Your car isn't timeless, its poop. and will be as it ages. bahahaha thanks for the good laugh
Warranty and resale are the reason I can trade mine in for another newer car pretty soon, and always have something i don't have to worry about shelling massive money out on every time it breaks down. For that matter i have a 1986 POS that i still keep and drive with a resale value of about 500$. because i recognize the difference between the luxury of a new car and the practicality of an old one.
Correction: no one in this thread likes it. Apparently no one likes yours either. Check out my build log, plenty of pages of comments on it there. it's to each is own, and you are retarded and think you know way more than you really due, just like most "classic" car fanatics.
