if hes burning out less gas.more gas , less clutch. LOL.
I never got tired of my 5 speed Jeep. Loved driving that thing. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifManuals may be fun, but wait a year, you'll get tired of it. When your just driving home from a day of work, you just want to relax, and not worry bout shifting.
I know what you are trying to get at but you are off base. First off all let me begin by saying his car's compression ratio is 9.3 which is fairly standard.Cot jones, you're a little off on your turbo argument. The thing about havving a turbo on the car is that it is never on the same stock engine. To accommodate the extra pressure a turbo has, the compression is lowered in a turbo vehicle which means the engine actually has less power.
For example my old 300zx had a 3 liter engine with a compression ratio of 10:1 from what i remember, however the turbo model's engine has a ratio of 7.8:1. Without the turbo, which includes lag below 3000, that engine has less power.
So if I threw a large turbo on my car that induced a ton of lag, it would have better low end than the stock car? Nice try.I know what you are trying to get at but you are off base. First off all let me begin by saying his car's compression ratio is 9.3 which is fairly standard. Second, the whole reason to lower the compression ratio is purely for compensation. If his i5 wasn't turbocharged it would have the higher compression ratio from factory, but the turbo also raises the effective compression ratio.
Meaning in a nutshell, your argument doesn't make sense. My point is that his turbo makes his car faster from 0-60, and without it mine would be faster. Well the same i5, without turbo, either with or without a compensated compression ratio would have less low end power than with turbo.
Your un-turboed 300zx had a lower compression ratio because it was designed to compensate. It's not made to run at 7.8:1 without turbo. obviously, it's made to run at 10:1.
The lag would only be a big factor if your initial compression ratio wasn't lowered. But the addition of a turbo should accompany a lowered compression ratio minimizing lag. So your argument is irrelevant.So if I threw a large turbo on my car that induced a ton of lag, it would have better low end than the stock car? Nice try.
You know crap.read what i typed. i did not say "same as" i said "form of" the only difference between the system on my lincoln and esc is that esc aids while steering. they are very similar.trust me, i know more about automobiles than you could dream of knowing.
False, because this is an incomplete answer. Traction Control applies the breaks when spinning, it is used in conjunction with the ABS system(such as on my car). In other vehicles with more sophisticated systems use timing retarding, reducing fuel, or boost control changes on turbocharged or supercharged application. Get your info straight //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifTraction control only keeps the wheel from spinning when accelerating by decreasing power to the wheel.
Hey shitdick, get your brain straight. Every function you just mentioned is synonymous with "reducing the power to the wheel."Ill just pick one example of you being wrong...
AGAIN!! who cares? we are talking about a specific application, its sad that you morons would rather play stupid and argue in circles then just admit when you are wrong.Actually it depends A LOT on the size of your turbo.
youre a jack@ss. i was referring to the braking not "reducing power" to the wheel. sorry I didnt throw the rest of the info in a new paragraph so you could understand it was a separate thought.Hey shitdick, get your brain straight. Every function you just mentioned is synonymous with "reducing the power to the wheel."
So, in no way was my statement false, you follow troll logic shitforbrains
And the only way the 2 systems could be said to work "in conjunction" is that they both share the same brake actuators and sensors, this obviously, is so because why would you install 2 of the same part when they do the same thing, when you can have 2 systems share the same part for different but similar purposes (increasing traction)?
it does matter. because the bigger a turbo on any application determines the minimal amount of lag you will end up with no matter the tuning.AGAIN!! who cares? we are talking about a specific application, its sad that you morons would rather play stupid and argue in circles then just admit when you are wrong.
Although i don't blame you i guess. The stigma I've been given would naturally make it difficult to respect my knowledge despite its extensiveness.
So explain to me how braking or increasing the friction on a turning wheel isn't "reducing the wheel's turning power." moron.youre a jack@ss. i was referring to the braking not "reducing power" to the wheel. sorry I didnt throw the rest of the info in a new paragraph so you could understand it was a separate thought.and in reference to abs and tc going hand in hand, i shared that info bc i didnt figure you were intelligent enough to realize the fact.
and they actually do install 2 different parts that have similar purposes, the master cylinder and the hydraulic brake actuator. they both force fluid to the calipers or wheel cylinders, just at different times.
