Making Sure
I have a stock alt
What size is the alt? I don't really see you any problems with just 4 gauge and that kind of power. Unless your alternator is tiny... I run 1200 watts rms with stock alt and 4 gauge and don't get too bad of voltage drops. Not enough to worry about it right now anyway.
My alt is a 105 volt one
Assuming you're referring to amperage, you should be okay. I personally always recommend the Big 3, but a lot of guys don't do it until they have to for whatever reason.
I always recommend upgrading the neg cables at the battery at least. with your system thats about all you should really have to do but if you do the 3 then thats cool too.
801
I had this same issue with my Sony. When I first got it I had speakers hooked up to the head unit without amplifiers and it worked fine. Once I...
Looks like half a dozen other makes/models on the market, rebranded . The shallow mounts look like they’re made by Pioneer but what the hay, one...
I think it worked .just odd bc it's brand new but I appreciate it man. haven't had any problems yet
Is that speaker in the existing rear deck? Are you running a sub in the trunk?Do you have that speaker on an amplifier?Are you using a stock HU...
Richie__Rich
Richie__Rich
Tallahassee, Fl
CrossoverOre
Brendon Jenness
    May 8, 2024
    May 8, 2024
