Making Flushmounted Speaker Rings Help
what tools?
a plunge router and a circle jig make this an easy effort.
if you just have a jig saw then you will use two pieces of wood. cut the inside piece to the woofer cutout dimension. cut the outside piece to the woofer basket dimension. probably easier to set both pieces on top and drill pilot holes through both so you have the same reference point for each woofer.
Brad894
Brad894
Somewhere, AR
fasfocus00
