mag vs MJ18...discuss
Thats true, I guess I could see why people would hate on it so much just simply because it doesnt cost so much. People tend to think you have to spend a lot or its not good. Of coarse its not the end all sub, but it seems very solid for the price //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
It is worse in the home audio realm, but price dictates capabilities to many people.
i much rather seal these first...ive never used a sealed enclosure and feel like id like to give it a try with these first...hence the reason why
Ok, hold on. Is that the working space that you have? If so, go ported - 9 cubes tuned to 30Hz. You will then have the best of both worlds.
Yeah but hes going to need a net volume of around 10~11ish cube to accomodate displacment, I think these would sound excellent in a little bit larger sealed enclosure....imo
Mostly the mis-informed, take almost any big name hyped up companies, all they have to do is make a shitty product, charge out the *** for it, and spend the rest of the money on advertising......//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Ok, if you want to go with 6 sealed, the following *inside* dimensions will work:
40.5"L x 18.5"W x 14"D
That assumes you will be using 3/4" wood.
Edit: fixed the dimension lettering.
dvrmstrng
dvrmstrng
DE
dvrmstrng
