Low tuning question
It's called Audible Frequency. The human ear, generally can only hear between 20Hz and 20 kHz.
YAH, but a sub doesn't have to PLAY that... The sq would be increased in the other frequnecies- according to the theory that a low tuned box makes a good sounding one.
SQ gets better as you lower the tuning because the frequency response curve levels off rather than peaking as much.
The main reason nobody tunes that low is that in doing so you approach the response of a sealed box which requires a TON less space. To give you an example...the port length of a 4 cube box with 54 square inches of port area tuned at 35Hz is ~23.6 inches. That same box tuned to 1 Hz would require a port that is 36,335 inches which is about 1400 cubes worth of port alone for a 4 cube box. Just not reasonable when you can acheive essentially the same results sealed.
Wouldn't having such a large port lower the excursion badly since that amount of space is like an infinite baffle?
Yes, I was thinking the same thing... THe efficiency would theoretically **** on a box such as that.
You'd think there'd be an equation to find the median point of maximum efficiency to the point where the sound would be the best.
But then, SQ is subjective, efficiency is not.
LoudCrownVic
1/1 of Team Team Team
LoudCrownVic
Scales Bump, IL
jrouter76
