Low budget amps, which would u pick?
What cheap amp would you choose if this is what your budget would allow?
  • Total voters
    7
I couldnt find any profiles that could run high on 4 ohms...
I did find a blitz that would work? Anything good on that?
*needing to push 2400 watts at 4 ohms* budget is $300
What kind of speakers are you hooking up? Subs or mids/highs? For 300 (or much less) you can pick up a pretty sweet amp off of ebay. If not, look around for some USAcoustics, decent amps, and fairly cheap. Point in case tho, I got an xtant 300watt sub amp for like $130 shipped. Brand new, works like a charm.
Edit: 2400 watts? //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif What brand of subs? I can safely say that the afformentioned amps you ......mentioned probably won't push that figure, even tho they say they will. Heck, if you need that many watts at that price point, ebay is gonna be your friend.
some MA 12's.. yes ebay is kinda like Dolamite..you can get some cheap hoes but diseases come with the terirritory..or freebies that you really dont want
(guy wang, i wouldnt know)
the specs...
Features
12" Competition Chrome Subwoofer
600 Watts RMS
1200 Watts Max
Dual 4-Ohm Voice Coils
240 oz. double Stacked Magnets
Mounting Depth: 6.5"
Mounting Diameter: 11.2"
Optimum Vented Box: 2 cu/ft
Round Port Diameter: (2) 4"
Square Port Area: 25 sq/in
Port Length: 16"
Optimum Sealed Box: 0.5 - 1 cu/ft
Subwoofer Specifications:
Subwoofer Size: 12"
Impedance: 4 ohms
Dual Voice Coil: Yes
Peak Power Handling: 1200 watts
RMS Power Handling: 600 watts
Surround Material: N/A
Sealed Box Volume: 0.75 - 1.25 cu. ft.
Ported Box Volume: 2 cu. ft.
Sensitivity: N/A
Frequency Response: N/A
Top Mount Depth: 6.5"
Cutout Diameter: 11.2"
check millionbuy for profile. They're really going cheap and they're not all that bad.
Another option would be the Lanzar 1200D on ebay. Going for $150 shipped right now and will do a legitimate 1200w at 1 ohm. It was the hot item a couple years ago and we all thought it was a good deal then at $220.
Some people claim Boss has a line or two of decent amps, but I don't know which ones, and they're probably not that cheap.
Pyle - Legacy - Soundstorm - Pyramid - Blitz --- they all work fine, but they're so randomly rated that you never know how much power you're really getting, but chances are it's a lot less than you think.
yeah but there were numerous failures on that amp though. I think only about 20 were reported but thats about it. I myself would get a VIBE1200D if i ran a budget system. Definitely a first pick if cost is an option.
"yeah but there were numerous failures on that amp though. I think only about 20 were reported but thats about it. I myself would get a VIBE1200D if i ran a budget system. Definitely a first pick if cost is an option."
which amp had the failures?
sick2sick
sick2sick
Marysville, Ohio
LBX2G
