Loudest set up in a single cab
Hey guys I have a 2002 single cab F150, currently with a SA-12 in a custom box built by CCStang but I want to go louder. What's the loudest set up I can do for the space that I have? Here's the max dimensions of a box that will fit back there:
width: 47"
height: 26"
top depth: 6"
bottom depth: 13"
Would like to know the loudest sub set up I can fit in that space. Budget would be under $1000 but I'd prefer to not spend that much.
What are your thoughts?
More power. I doubt you will efficiently fit much more cone area. If you were to go with more cone area I would think 2 10s would be your best bet
Something like a ZCON 12 on a 3-4k amp would be great. I happen to have 2 used ZCONs in the classifieds //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
width: 47"
height: 26"
top depth: 6"
bottom depth: 13"
In the past,I put 4 Kicker C10 ten inch subs behind a seat in a sealed enclosure of a 78 chevy truck on an Autotek Mean Machine 99, and hit pretty dammed hard.Ill bet you could get 4 slim Sundown tens within that amount of space and d pretty well
Power, power, power. Thats about it. The bad part is your mounting depth whats your max like 6.5" maybe 7"? Any real beefy subs are like 9" long. Unless you invert i think youre at the hest you can do without vehicle modifications
width: 47"
height: 26"
top depth: 6"
bottom depth: 13"
Texted you
If the seats are a split bench. Then you can do a nice 15 in there easy. I did one for a member here a few years back. A dc team lvl 5 on a powerbass xa 3000 it was pretty loud. But the pass seat was moved up more than the drivers seat. Actually still have the box diagram to
Scathed
Scathed
Dayton, OH
mylows10
