Sold Lots Of TOP OF THE LINE Car Audio For Sale Here! MA Audio, Kicker, Monster
MikeySpice
New York City's Finest
EVERYTHING IS FOR SALE!
(specs on everything is below, prices are firm, references available)
EMAIL ME AT: MJAG321@GMAIL.COM
MA AUDIO HC4002 AMPLIFIER(brand new): $320 SHIPPED!
MA AUDIO HC504 AMPLIFIER(brand new): $200 SHIPPED!
MA AUDIO HC1002 AMPLIFIER(used): $160 SHIPPED!
KICKER 12” L7 SOLOBARIC SUBWOOFERSS (used): $280 SHIPPED!
MONSTER 1.0 DIGITAL CAPACITOR (brand new): $100 SHIPPED!
TAKE IT ALL FOR $1000 SHIPPED!
LOCAL PICKUP IN NYC IS WELCOMED.
AMPS:
BRAND NEW: MA AUDIO HC4002 AMPLIFIER
DOES 4000 WATTS RMS!
HC Series features:
• High Current,Non-Regulated Power Supply
• Double Sided PCB
• Cooling Fan (Thermal Regulated)
• 24dB Active Slope Crossover
• 18db Variable Frequency Bass Boost
• Variable Phase Shift(180 degrees)
• VU Meters
• Line Out
• Protection Status Indicator
Specifications:
• Bass Frequency Range: 45Hz to 90Hz
• Bass Boost: 0 - 18db
• Frequency Response: +- 1dB from 10Hz to 40KHz
• Signal to Noise Ratio: > 100dB
• Input Sensitivity: 100mV to 7V
• Channel separation(AT IW): > 60dB
• Damping Factor(ATIW / 50Hz): >240
• Typical Current Draw At IDLE: 1.4Amps
Stereo Power
• Into 4 Ohms @ 13.8V DC : 2 x 400W
• Into 2 Ohms @ 13.8V DC : 2 x 700W
• Into 1 Ohms @ 13.8V DC : 2 x 1200W
• Into 0.5 Ohms @ 13.8V DC : 2 x 2000W
Mono Power:
• Bridged Into 1 Ohms @ 13.8V DC : 1 x 4000W
Recommended Fuse Size:
• HC4002: 40A x 4
Dimensions:
• 2.3" x 10.8" x 26.4" (H x W x L)
BRAND NEW: MA AUDIO HC504 AMPLIFER
Bridgeable
Tri-Mode Capable
Low Level Inputs
Bypass Line Output For Connecting Multiple Amplifiers To The Same Signal
Variable Low-Pass Filter 45- 1220 Hz
Variable High Pass Filter 100-800 Hz
Variable Bass Boost 0-18 dB
Variable Bass Boost Frequency: 45-90 Hz
Variable Phase Shift: 0-180 Deg
Variable Output Level Control
Thermal, Short Circuit & Overload Protection
VU Meters
Cooling Fan
500W X 2 Bridged 4 Channel High Current Amplifier
4 X 50 RMS @ 4 Ohm
4 X 90 RMS @ 2 Ohm
4 X 150 RMS @ 1 Ohm
4 X 250 RMS @ 0.5 Ohm
Bridged 2 X 180 RMS @ 4 Ohm
Bridged 300 RMS X 2 @ 2 Ohm
Bridged 500 X 2 RMS @ 1 Ohm
Dimensions: 11-1/2" W X 2-1/2" H X 17-3/4" L
USED: MA AUDIO HC1002 AMPLIFIER
2-channel high current amplifier
STEREO
4ohms---2x100w
2ohms---2x180w
1ohms---2x300w
0.5ohms---2x500w
MONO
4ohms---1x360w
2ohms---1x600w
1ohms---1x1000w
High current, non-regulated power supply
Double sided circuit board
cooling fan
24db active slope crossover
18db variable frequency bass boost
variable high and low pass filters
variable phase shift (180degrees)
vu meters
line out
protection status indicator
USED: PAIR OF KICKER S12L72 SUBWOOFERS
(THESE THINGS POUND!!!)
• 75-750 watts RMS (375 watts each coil)
• Dual Voice Coils
• 2 Ohm Version
• 1,500 watts Peak power
• Aluminum deposit cone
• sensitivity 87.4 dB
• Non-resonant aluminum basket
• Rubber surround (For better endurance and protection)
• Dual 4-ohm voice coils
• Frequency response 20-100 Hz
BRAND NEW: MONSTER DigiCap™ 1.0 Farad Stiffening Capacitor
Low ESR allows large amount of current transfer in a very short period of time, without voltage drop.
Detects voltage drop from battery across any load for improved current capacity of your 12 volt system.
Greatly improved transient power response, bass impact and definition.
Developed by car audio specialists Richard Clark and David Navone exclusively for Monster Cable®.
24k hard gold contact terminals for maximum conductivity and corrosion resistance.
Now available in Monsterous™ silver.
Digital Voltage Meter to monitor power.
MikeySpice
MikeySpice
New York City
MikeySpice
