Losing output when you invert subs?
But that would require buying a tool box, which is more money...and it is compact, its a ranger
You can get battery covers. We have one that powers a deer stand (yes, I know) and it has kept that battery in good shape.
Then again, you have the possibility of someone stealing it. I just think you will regret putting the batts in the box.
Nothin wrong with bein country //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Where can you get these battery covers??
I'm losing it again because my batteries are going inside the box. I'm not sure how i'm going to seal the box well with a + & - wire going in and two of each coming out.
The ports will be external as well
Use some 3/8" all thread to make double sided terminals and bolt ring terminals inside/outside the box, problem solved //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
You could design a new box...can we see pics of your setup?
I'll get some tonight, the box will be subs up(inverted, death penalties //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif) ports up w/ 4 4" external aeroports tuned to 32 hz off a Fusion 4000D @ 2 ohms
My truck is weird, the back of it has a big hump for the drivetrain...i think...so the box is like a big L
ZOMG! check out my build thread better yet here check my design im doing right now! obviously mine is way to small for what your running but the same idea
at school, pics are block //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif i'll check when I get home
This I know...but I can't make the box any smaller to make room for batteries...its hard to explain unless you have the truck right there lol
I removed my receiver hitch and made a battery rack that mounts under the truck and uses the existing frame holes.
bunkerking09
Current Status: Win
bunkerking09
Kansas City, MO
GMCJimmyslt2000
