Looking to get low
You don't want to rattle the doors off but you want to tune that low with a mid level 15?
It's hard to explain while typing, I'm looking to get pure Sound Quality out of a 15 since I can use one, without it being boomy.
I've never gone for anything like this, so if anyone knows what I do need, please let me know.
Really you can make most subs play fairly flat depending on your enclosure. What's your budget?
Get yourself a fi q. Put it in an enclosure with 3.3ft after displacement tuned to 29.43hz.
~200 max, the Q is definitely not the right sub for this build, way too much power.
Does that oa woofer play flat in a smaller enclosure? When I modeled that sub up a while back I think it needed like 7ft3 tuned to 23hz to get a flat curve.
In his price range it is most likely the best "new" option. They don't play straight flat without large boxes.
Doesn't have to be new, either should've mentioned that. I looked at your Titaniums but I don't know anything about them, do they like larger enclosures, maybe around 3 cubes?
On 600-1k 3 cubes would be great. They are rated at 1500rms so the box size would have to be larger to compensate. They sound great and have a great response curve.
Do u even have the t/s specs for those drivers? If u do why are they not listed in your ad?
Op.... if you think the q needs to much power what do u think these eclipses need lol Good luck with your build your going to need it.
It's all in the box the eclipses are only 12's... they are good for 2 cubes at rms, so there is plenty of room to expand.
Fs 27.68 Hz
Qms 5.0
Qes 0.351
Qts 0.328
Re 5.9 ohms
Vas 32.4 liters
Sd 430 cm^2
Xmax 23.15 mm
Bl 28 Tm
Pe 1000Wrms
in series
Fs 27.68 Hz
Qms 5.0
Qes 0.351
Qts 0.328
Re 5.9 ohms
Vas 32.4 liters
Sd 430 cm^2
Xmax 23.15 mm
Bl 28 Tm
Pe 1000Wrms
in series
I'm familiar with these drivers and I posted the specs in your thread.
UnderFire
UnderFire
Dayton, OR, 97114
KRYPTO
