Looking for sufficient electrical
jfsh90
Once my tax money rolls around I am looking to revamp my system.
I will be purchasing an AQ1200D.
Should I run 0 gauge or is 4 gauge fine?
My Aurora has the battery mounted under the back seat. I was wanting a bigger battery than stock. Any reccomendations?
Sum it up:
-4 or 0 ga?
-Reccomend battery
Thank you everybody for you time!
Not sure what size battery it is, I'd go with a batcap 2000 //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
And it'd be fine to run 4 ga. How long of a run is it?
4 gauge is fine for that amp, as long as your door speakers amps are less than 300watts total. And as far as a battery look into a Kinetic 2400 if it would fit. Or even better a powermaster.
You can use a battcap as a replacement for a stocker? I thought they worked different than normal batts?
Yea I haven't done the big 3 yet.
I've been running my Sundown for about 6 or so months and at full volume my car (completely stock electrical) will run no lower than 14.5 volts.
Will running 0 ga hurt my car at all? I just figured it would help dissapate heat
It won't hurt your car, as long as it is fused //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Yep. Dave (12 Gauge) has one that replaced the stock battery in his CRX.
Does he have any problems with the car starting after it has been sitting for a while?
1/0 will not hurt your car, if anything it will be less stressful than smaller gauge wire due to the ability to carry more current.
Cool //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thank you so much for all of the quick replies! They are all appreciated.
I am also on a stock hu at the moment and, quite frankly, it's shit.
I am interested in a deck with a built in eq and 3v+ outputs.
Premeir 880prs ftw
jfsh90
jfsh90
cedar rapids
jfsh90
vegang
vegang
