Looking for small 4 Channel Amp
Bump. How is Soundstream's reputation?
Their Stealth Series STL4.500 would work I think.
SPECIFICATIONS STL4.500
Channels / Class 4 ch. Class A/B
RMS Power 4-Ohm 80 x 4
RMS Power 2-Ohm 125 x 4
RMS Power 4-Ohm Bridged 250 x 2
Input Sensitivity .2-5V
THD (4-Ohm power) 0.03%
Frequency Response 15-25kHz
S/N Ratio (4-Ohm power) 100dB
Damping Factor (100Hz) >200
Stereo Separation (1kHz) 40dB
Channels 1&2 HPF or Subsonic 50-4kHz
Channels 1&2 LPF 50-4kHz
Channels 3&4 HPF 15-500Hz
Channels 3&4 LPF 50-4kHz
Bass Boost 6/12dB, 50Hz
Phase Control No
Recommended Fusing 80
High Level Input Yes
Remote Gain Control No
Dimensions
(6.5"w x 2.125"h) 11.25"
Thanks for the recommendations guys. That PPI 900.4 had my eye for a while. I might end up going with that, but with it being a class D, is there a noticeable difference in sound quality?
It's a very transparent sounding amplifier, meaning it amplifies the signal without adding anything to the sound. For a sound quality system this is often very desirable, although if you're expecting a "warm" sound it will not deliver that. I have never had a customer tell me their P900.4 let them down. The value is excellent.
JungleGym
JungleGym
United States
04murdalanche
vegang
vegang
