looking for best amp under $350(new or used) to power 2 RE Se's in sealed box
Bigpete757
fl
What is the best amp I could get for under 350 (new or used) that would be a good match for 2 Re se's in a sealed box? I know I will need some power, thinking at least 700 rms to each sub, so please give me some advice as I am stuck on this decision. I have looked at high end brands to low end brands trying to find a decent combination, but are not sure. Thanks in advance.
that is on my list of choices, but aren't sure if its enough to push them in sealed box. I heard they sound better with alot of power. Also, maybe looking for something with a little better sq, either way just want to find something good that will not draw too much power. I would like it to be 120 fuse or less, no more than 150. I have looked into the memphis m line and read good reviews, so that is also high on my list. Others are the crunch gp line, maybe kole/spl/power acoustic/similar, helix dark blue, rd audio, cadence zrs, and more. I know there is probably quite a few people are using the same RE se subs and would like to get some opinons of what works the best. There has got to be something pretty **** good I could get for my setup that is under 350 (new or used). Thanks for the replies so far.
The AQ2200D is about $40 over your budget and you would need to gain it down some but you would have the power to upgade your subs in the future.
if you need about 1200 rms, feel free to ask tron terror what to use
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
I've thought about kicker because they put out some power, but heard they are not to clean and are looking for something along those lines. I will look into the sundown, however read somewhere that they don't produce that good of power. I know alot of people on this forum use them and like them, so we'll see. I looked up tron terror in the user names but was not listed. (Etac) I am not sure what you meant, but if you could clarify this that would be cool. If anybody knows any others, I would greatly appreciate it. Thanks.
Hifonics 1800 watt amp, probably does like 14-1500 rms.
Ed nine.1 rated at 1200 watts, but that is at 12 volts
MTX 1501d I can't remember what this is rated at, but I think it does around 13-1500 on good voltage.
Rockford fosgate 1501bd
Like somebody else was saying the sundown 1500
Orion 1200d Under rated amp.
You can find all these on ebay used for not very much money. I know the hifonics sounds kinda lame, but you can get it for like 150 bucks.
Bigpete757
Bigpete757
fl
bigbangtheory
