Looking for advice on a sub/amp for my car
OCS doesn't list stock levels on their site for anything I've looked at. I can't get SS so I don't know the answer to that question.
Well poop. OP, guess you'd be better off the PPI monoblock and a separate 4-channel if you choose to do that later on
I'll have the PPI P1000.1 in stock next week and I have 6 P900.4s on hand. I can do drop shipments as well. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If I hadn't received my eclipse 5-channel in trade, I would have pmed you already. Love those phantom amps
d2 ,run the amp at 1 ohm
Running it at 1 ohm wouldn't be overkill?
The d2v3 is rated at 100 -400w RMS (or 200RMS per other sites) and the p1000.1 at 1 ohm is 1000watts? the PPi's are said to be under rated.
At 4 ohms the PPI p1000.1 is still 580 watts, for that mater the PPI P600.2 is 600 at 4 ohms and a little less money and half the size.
They are not underrated at all. If anything it might not do quite rated if you go with the I'd max then then amp power won't be an issue. You can always adjust the gains to match the power you need
You'll be extremely happy with a 10" end result, following mylow10 and double 07's recommendations! Even if they said do 8's, the system would exceed your expectations.
So I'm very new to this. Would the amp not be able to effectively power the d4?
Im figuring things out also. I got the p900.4 and was considering the p600.2 for my 10in sub, but now im leaning toward the p 1000.1. Only$50 more.
The dual 2 ohm sub can be wired for 1 or 4 ohms, so if you wire it for 1 ohm you can get the full 1000 watts out of the amp. You can't get th d4 to 1ohm.
exactly it will do 2 or 8 ohms
Okay, I think I'm starting to get it. I sent double07 a PM. I need to make sure my desktop (full tower beast) can fit in my trunk, so I'll have the max measurements ready for him by Tuesday. He had told me, however, that making the box from side-to-side looks a bit better. Would I be able to fit two 10" subs in a box with the same amount of cubic feet? And will this amp power two subs? This is more of me being curious than seriously considering going this route.
Sovelin
Sovelin
Littleton, MA
Sovelin
