what determines voice coil power handling capability?
Heat dissipation properties will play a small roll as well, as a flatwound coil will be able to dissipate more via its design/shape, as opposed to a heavy gauge 8-layer round wire coil. More surface area ftw.
Basket design and pole piece/motor design also contribute to overall cooling capability along with voice coil properties
Absolutely. You can't have a coil baking inside a motor and basket structure that doesn't want to allow any cooling.
Another concept as well.. Lamence terms... The motor's "power" needs to be able to allow and control the energized coil's movement as well. A high powered driver, or coil in this instance, needs a powerful motor to help with controlling and keeping it inside a certain portion of the gap so the power sent to the coil isn't simply heating up the windings as it sits static, rather, turning the power through the coil into mechanical energy ie movement and eventually acoustical energy. As well as other types of mechanical and heat energy, but those are what we are NOT after. We sound efficient drivers that make sound.
But along with the movement thing, basket design, spider diameter, surround capabilities, and excursion as a whole plays a role too.
Speakers are very finely designed and fine tuned machines.
the thermal cap comes down to the coil and the cooling of the motor.
example; take 2 exact coils with same spiders and cones. put 1 in a dd9500g then other in a re audio sx. the 9500g will handle 500-600rms more power due to better motor cooling...
..... Annddd what do you know Sir?
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Are the difficult design parameters the reason why dual voice coils subs exist? This way you can have a 600wrms sub divided by two coils to prevent too much wattage through a single coil, right?
Are the difficult design parameters the reason why dual voice coils subs exist? This way you can have a 600wrms sub divided by two coils to prevent too much wattage through a single coil' date=' right?[/quote']
no, dvc exists for the purpose of allowing different wiring configurations in order to wire your amp as low as it is stable for, to get the most power out of your amp. less resistance = more power
So just because a sub woofer has 2 voice coils, doesn't mean it has more power handling ability than a single voice coil sub?
Then why do some manufacturers advertise a single coil sub as having a 250wrms capability, then advertise a similar dual voice coil version as having 250wrms EACH?
I've never seen that... Can you show an example.. bit no as others said a dvc is only useful for wiring options. Actually I can post hundreds of examples of subsbthat have a svc and dvc option that have equal powerhandling
Beatin'
Beatin'
MI
T3mpest
