looking for a small 5 channel amp
I need something physically small that can power 4 mids and a woofer. Nothing crazy, 400 rms for woofer and maybe 80 rms per speaker would be fine.
Most 5-channel amps are stable down to 2 ohms on the mono channel. Do you have speakers and a subwoofer now? If yes, what impedance is the subwoofer?
The woofer is a factory Honda pilot 10'' that is 2 ohms. I want to replace it with a entry level 10'' that will be about 200 rms. I don't need anything crazy just a little upgrade is all I need. I then want to replace the door speakers with coaxial 75 watt rms entry level stuff too. The trick is to make it fit in the compartment that is under the back bed. It has too be a smaller unit.
I can get you everything. A small 5-channel amp, 10" sub, speakers, amp installation kit. The sub made need a spacer ring to clear the magnet as the stock sub is pretty shallow.
Keep in mind that it's my wife's car so very entry level will suffice. I have amp kit so just need amp, woofer, speakers and spacer. Let me know make and models please .
mrpep
mrpep
chicago
Inferno333
