Looking for a quality amp that won't break the bank.
Gene3x
I have a Kicker 850.4 and it seems to fizzle out at a decent volume. i just need 2 channels to run some image dynamic speakers wired to 2 ohm. They can handle ~350 watts rms. Since I am running 215 watts at 2 ohms and wanted to go up what would be a good replacement?
I was looking at the SOUNDSTREAM XTA880.2 What is the catch with these amps? why so cheap?
SS makes some nice higher priced amps, but if you open up an "X-treme" you'll see a board very similar to the Profiles/Lanzar Vibes etc. It's really nothing more than a decent amp on the budget side in quality. Certainly no Kicker.
Cool Man. it looks like you are a wakeboarder also. I am running the Defcon IV's in my boat. What decent priced amp would you suggest? I am looking at a Tarantula TR-700/2 also, or should I go with an old school amp like an Orion SX2150?
I just got it for $250 plus $30 shipping. So I will now sell my Kicker 850.4, but is adding a third amp going to cause me problems?
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Thanks
Also since the INPUT SENSITIVITY is 0.15 - 12.0V . That should help correct?
Total power able to draw at once? Total RMS?
Now: Kicker 850.4 is 215X4 at 2 ohms= 860 RMS & PPI 1500
New setup: Tarantula is 350X2 at 2 ohms= 700RMS, & JBL 75X4 at 4 ohms=300RMS, & PPI 1500
(I probably would not turn the gain all the way up on the Tarantula)
Yea (2 ohms also) it is over kill but I got the amp for cheap so I keep the gain down there also. It is good to have more power than you need so things can run without being under alot of strain right?
Definitely.
I don't think you're going to notice a significant difference going from the big kicker to the SS and JBL.
To make a rough estimate on your current draw...~500w for the SS, and ~500w for the ppi, plus another 300 for the jbl.
1300 at 60% efficient (give or take) = ~2100w
2100/13 = ~160A
Factoring a ~30% current demand for music vs. tones gives you around 50A rms when you've got it cranked.
I would guess the problem - specifically - is those 100A+ peaks are dropping a good volt or 2 and the amp(s) doesn't/don't like it.
I would say unless your alt's 80A+ that's probably what's happening. Once we know what voltage you're getting it should help nail down exactly what the problem is.
If I don't notice a big difference between either setup? Then what can account for the distortion? The speakers? It just gets a little fuzzy when cranked. Real fuzzy with certain songs. I will go check the voltages tommorrow.
I also need to address the whine through the speakers with nothing but the amp trned on. Sounds like it may be a fan because it changes pitch when you turn on the blower or lights ect.... Thanks again Bro.
Gene3x
Gene3x
Dallas, TX
questionaire
