Looking for a 3 or 6 channel amp...
agarabaghi
I need an amp to run a set of full range speakers ...
I have 3 tower speakers on my boat which each have a 4 ohm load...
So id like an amp that could do 400 - 450w /rms x 3 at 4ohm...
I found one:
SD6 l Wet Sounds Sinister Series Amplifiers
It's a bit too powerful @ 538w/rms x 3...
The speakers are rated at 300w/rms for 2 of them and 600rms for 1 of them...
Im wondering if I tuned properly if it would be ok...
im pretty sure they are full range tower speakers. meaning he would need a full range amp to run them. the 600W rated one is probobly a sub tower speaker. finding a 4 channel amp that puts out 300/channel will be EXPENSIVE, but it can be done. you would just run the lower powered towers on chanels 1 and 2 and the higher powered tower on 3/4 bridged.
Matt
That amp you linked will work fine. Just turn the gains down on the speakers with lower power handling. The only other amp I can think of that's marine rated is the Clarion XC6610, and with 3 pairs of bridged channels it's rated for 250W x 3 @ 4 ohms. It's underrated, but not by a huge amount.
I actually just realized the 6 channel i have in the boat now is EXACTLY what i need lol...
Bridge channel 1+2 and 3+4 and i get 200w/rms which is the rms of the pods (200rms / 400peak) and bridge 5/6 and i get 600wrms which is actually what was powering the middle tower speaker....
$899 though...
So now i need to figure out if running the SD6 for $1200 and possibly damaging the Rev8 speakers is worth it, or go matching on the SYN6
---------- Post added at 01:03 PM ---------- Previous post was at 01:02 PM ----------
If i do go SD6 road i can always just run channel 1 and 2 at 185watts/rms
agarabaghi
agarabaghi
Orlando, FL
agarabaghi
    Jun 24, 2026
    Jun 24, 2026
