looking for 900-1200wrms @ 1ohm
Of course there are always going to be product biased suggestions but if you are at all interested in SQ, get an A/B Class amplifier whether it is ours or any other companies.
At 1000 watts, you will not be over taxing your battery and the differance in current draw from a D-Class to an A/B is not significant and of course an A/B will sound far superior to a D-class.
1-2% THD & N D-Class is a far cry from .05% THD & N from an A/B-class.
Nine.1 is a great amp, as is that Sundown.
I have an amp that is very similar to the Sundown, it's an RD 1000.1, you can expect a little more than 1000w rms out of her
I'll let her go for 200 or under, send me a PM if you're interested. Cosmetics 8.5/10 and 100% functional no questions asked
And I can get you as much feedback as you'd like.
My Sundown runs at .01% THD
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
nine.1 is too much power at 1 ohm
From there web site:
Double Sided Through Hole Epoxy PCB
Daisy-Chain Through Output RCA
Efficiency : 86% @ 4 ohm, at 100Hz
24dB/Oct Variable Crossover
Multi-Way Protection Circuitry
(Thermal/Over Current/Speaker Short/Speaker DC Protection)
Variable Subsonic Filter
Variable Bass Boost
Variable Low Pass Filter
Variable Phase Shift
Zero(0) Gauge Power Supply Connectors
Tested Voltage & THD : 14.4V & Less than 1% THD
Operating Voltage : DC 10V~16V
Digital Class-D Linkable Mono Block Amplifier
1 Ohm Stability
RCA Line Input and Master Output
24dB Octave Crossover Slope
Wired Remote Controller
Variable Bass Boost
1 Ohm Stability
Yeah, I looked that up after i stated that //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
My 100.2 was .01% I guess i thought they all were!
My bad.
ballistik101
ballistik101
Los Angeles, CA
Team Maxxsonics
