amp frequencies
ok the low pass filter goes between 50Hz - 250Hz the high pass does 80Hz - 1.2KHz
so do i just make a calculated guess as to when i think i have adjusted it to the correct frequencies? and what should the high pass be set at?
The super bass option goes between 0 - 12db i have it set on 6db.
for subs, you use LPF ONLY.
Set it to 80hz as suggested, you will need to set a subsonic filter too!
If you do not have one, i hope you are using a sealed box because if you are not, your sub is a lot more likely to get damaged.
If you do have this filter, you must set it just a couple hz below tuning for safety reasons.
Turn your bass boost all the way down to 0db. This will induce clipping.
seatslayer
seatslayer
home
Ed Lester
BP1Fanatic
BP1Fanatic
