Looking for 6.5"s
if you must run rear fill, i would highly reccomend some form of time alignment. also, are you going to be powering these with an outboard amp? for coaxials, my first choices would be either the pioneer tsd-650r, the polk momo 6.5"s, boston SL65's, diamond d3650's, or the zapco iforce 650's.
i dont know exactly what outboard is...and i dont know what amp yet, it will depend slightly on the speakers i choose to run...and what determines if you have to run rear fill?
Would the best choice be to run a component sytem in the front and coax's in the back?
Most folks say to just use the factory rear speakers and have the fader set so you can barely tell that they are on. You really do not want alot of midbass or treble coming out of the back because it will screw up your imaging. Take all $250 and spend it on the front comps and make sure you give them a good amount of power and most importantly read the sticky on how to properly deaden your doors.
outboard=external=not deck power. say in a coupe that was mainly a 2 seater, like a mustang or camaro, i wouldnt run rear fill cause nobody wanted to sit in the back of my cobra. but in say an suv where people are always in the back seat, or in a sedan, or something classy like that, i would run rear fill, but only if i had time alignment.
chris96camaro
Foreign and Domestic
chris96camaro
Charlotte, NC
bri487
michigan born
    May 14, 2026
michigan born
    May 14, 2026
